Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 throttle hold function >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 07-03-2007 | 08:38 PM
Default throttle hold function
hay all im using the futaba 6exhp tx. on the throttle hold settings it only lets me go to 50% not 75 or 100 is there a way to over ride this.
Old 07-03-2007 | 09:34 PM
HeliTB's Avatar
Default RE: throttle hold function
Throttle hold is typically used for gas/nitro power helis for doing autorotations, which keeps the engine just above an idle. It allows the pilot full use of the collective without the throttle being active.
I use throttle hold for my T-Rex like an off/on switch. I use it when carrying my heli to the flight and after a flight so the helit doesn't accidentally spool up if I hit the throttle during the transport.
I set it for -2.
Old 07-04-2007 | 07:37 AM
BarracudaHockey's Avatar
You are confusing throttle hold with setting up throttle curves to keep your head speed constant.
