Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 Trex 450S tail question >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 08-24-2007 | 03:03 PM
Default Trex 450S tail question
I just finished setting up my new trex 450S not SE but S. Everything is nice and it flies smooth, think its set up pretty good, the local heli wiss at the hobby shop says its nicelly set up. But i have a question though. Im using a gy401 gyro with a hs-56 servo and a dx6 radio. I use the remote gain adjusting through the radio. Should i put the delay circle on 0 on the gyro or it doesnt mater where its at. Also when im hovering if i turn the nose to the left i get a fast rate turn cus of the gyroscopic preccession, but if i turn thenose to the right it does it slowly, i mean really slow, my servo has full travel and i still turns slow. Does anyone know why or is having that same problem.
Old 08-24-2007 | 03:58 PM
BarracudaHockey's Avatar
Default RE: Trex 450S tail question
You probably use the end points in the radio to adjust your servo travel?
Old 08-24-2007 | 04:38 PM
Yeah i did, but when i use the rudder it has the full range, like when i go left it slides all the way and when i go right it slides all the way still. It has full travel. Thats why it has me stomped.
Old 08-24-2007 | 05:07 PM
929freak's Avatar
I had mine the same way till one of the local heli pro's told me to turn up my end points...the way he explained it was that the ep is used to control piro rate(how fast it turn on axis) and that you use the travel limit on the gyro for the actual end points.....worked for me when I had the same prob....my end points are up around 120%
