Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 600 E Normal Set-up only ? >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 10-17-2007 | 09:03 AM
Default 600 E Normal Set-up only ?
Ok here goes I want to set-up my 600 e for normal flight only at this time. I need help setting up my pitch , throttle curve without getting into idle up, hold etc. have a 6 ex radio. Currently it's flying ok but I feel the head speed is too low. Anyone set-up like this and what are your settings. Thanks
Old 10-17-2007 | 09:07 AM
madmodelman's Avatar
Default RE: 600 E Normal Set-up only ?
I've just set mine up like that with a scale fuse on it, same rc, I'll have a look when I get home, I can remember 0,40,65,85,100 throttle curve though.
Old 10-17-2007 | 10:46 AM
Just leave the throttle curve linear and run pitch at something like 0, 10, 30, 60, 100. You should have plenty of head speed and hover around 75% throttle.
Old 10-17-2007 | 02:11 PM
Hi, I run pitch at 0,25,50,75,100, if you set normal and idle up the same for the time being you will have no accidents if you get a switch moved in error, Gary.
