Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 Upgrading to eccpm - Is this all I need? >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 11-12-2007 | 07:22 PM
Default Upgrading to eccpm - Is this all I need?
I just bought a computerised radio so i'm thinking about upgrading the 450s to eccpm. Are these parts all I need? Or do I need to buy a new frame also?
thanks in advance
Old 11-12-2007 | 07:48 PM
Default RE: Upgrading to eccpm - Is this all I need?
You do not need a new frame. The HDE and CDE frames are identical. You should only need the parts shown in your post to convert it...
Old 11-12-2007 | 08:26 PM
thanks for your quick reply!!! Could you tell me (if you can) if this setup will make more room for the battery? because in the present configuration its a nightmare to fit my 2200mah lipo in front of the motor (below the ciclic servos). the best thing i did was buyng a 2600mah cheap chinese lipo (longer and thinner) and fitting it below the frame (that improved flight stability dramatically).
