Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 trex450SE V2 question >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 12-02-2007 | 09:35 PM
Default trex450SE V2 question
hey guys, the tail assembly on the V2 is giving me a problem...the little roller thats on top that pushes down on the belt keeps sliding to the right and making my belt mess up. any1 else experience this problem? i have to keep pushing it back in the middle where its suppost to be.
Old 12-02-2007 | 09:56 PM
BryFlyGuy67's Avatar
Default RE: trex450SE V2 question
You must be joking! This little roller has been the subject of many a thread around here!
Seriously, you should take your tail assembly apart and remove the roller. You might want to replace your belt as well...
Do a search on your problem. You will be surprised at how many threads you will find!
Old 12-02-2007 | 10:34 PM
really.....this little roller causing so many problem? what is its purpose anyways, other than just to be there i dont see how it effects anything....ill def take it off before i fly again.
Old 12-02-2007 | 11:25 PM
BoysToys's Avatar
Bry is right. Most people recommend removing the idler on the tail. I still fly with mine and it has not caused me any problems. However, after hearing of all the stories of shreded belts I am going to remove mine the next time I change my belt. I also use a Gates belt from Tech Model Products and have had much more luck with it than the stock Align belt.
Good Luck and have fun!
Old 12-03-2007 | 09:14 AM
I am running a Gates belt as well, FYI.
Old 12-03-2007 | 11:48 AM
I have always flown with the rollerskate. No problems. If it works, don't fix it. Finless Bob flys without it.
Old 12-03-2007 | 01:42 PM
Yeah, when I first read about the thing, I decided that I wasn't going to take aparrt my tail JUST to remove the roller. However, I bent a tail rotor shaft the other day and removed it then.
It sounds like his is causing problems, though and should probably be removed.
Old 12-03-2007 | 02:20 PM
well i just removed it...but not in time i guess...the belt is already started to fray, but im just going to fly with it until i order a new belt...if i crash i crash, havnt even crashed it yet and ive replaced the belt twice, kinda sad i crashed my falcon 6-7 times and it still has the stock drive shaft in it.
