Mode 1 set up and Mode 2 setup
MD
When you are setting up your head and swashplate links, are the settings the same no matter the mode that the Remote is in? I was watching bob's video on setting up the head. He is setting up for +/- pitch clearance on the swash plate.
If you mean, Do I use the same +/- pitch for all flight modes? Only the top half is the same for all three, Idle 1 and 2 are identical -12/+12, normal mode only goes down to -5
MD
I did not do a good job asking the question. I meant to say, are the head and swashplate settings(Linkage) up the same. Specifically are the linkages and clearances the same for either type of flying. I am not asking about the program settings in the remote.
