T-Rex heli For all you T-Rex lovers out there, this where you can post!
flight time
Old 12-28-2007 | 07:24 AM
Default flight time
what is about the average flight time for the trex and what battery are you using to get that flight time.
Old 12-28-2007 | 07:27 AM
exeter_acres's Avatar
Default RE: flight time
depends on gearing and flight ...MANY variables...
but with a 2070 or 2100mAh battery....
general flight.. learning, hovering, a bit of FF, with head speed around 2200 to 2400 rpm
about 10 minutes or maybe a scosh more....
hard 3D with head speeds in the 3000+ range...
about 5 minutes....
Old 12-28-2007 | 09:30 AM
I am using the same batts in both of my v2s. I only get about 7 to 9 minutes flight time. [sm=shades_smile.gif]
Old 12-28-2007 | 09:52 AM
LOTS of variables,,,, I like my head speed a bit faster so the heli is more responsive... so in general flight at a higher head speed... 8 minutes is normal....
when just starting out a slower head speed is OK... so you can get up to 10 +
but like mentioned, it is a trade.. faster head speed = a better flying trex = shorter run time
Old 12-28-2007 | 10:03 AM
Higher head speeds give you more options if you need it.. I don't do much 3D just basics..
Cheers
RC-Shamus
Old 12-28-2007 | 01:40 PM
I also don't fly 3D. I fly scale. thanks for the info
Old 12-28-2007 | 05:45 PM
HeliTB's Avatar
I get about 5-7 minutes with 13T pinion @ about 3000 rpm. Lots of FFF, rolls, flips and inverted.
