Never messed with this function before on my DX6
PA
While at the field I had a near mess up. While pluggin in my Trex my dx6 topples over..And goes full thottle..."BUT" trex doesnt go ape Sh&t on me instead the esc goes into I suppose voltage mode or something. I never really messed with this function on my Heli..Now on my parkzone airplanes I have to set voltage for lipo or stardard battery voltage this way... It went thru a series of beeps, I unpluged everything and turned the controller back on "laid it down this time" plugged up the rex and it started to sing differently. Then when I was spooling her up I noticed it took 2 seconds or more to actually get full spool. So I figured ok it is messing with the voltage. Took me awhile to get this thing reset by letting it go thru a complete cycle of beeps before it was back to normal.
So question is with a DX6 Trex 450sa with 35 amp align esc, 430 motor..using a 2100 lipo.. what do all these different series of beeps mean? What type of settings are they putting the esc into? This is one thing Im a total noob on..I never messed with these settings before but I am curious at this point..
WA
possibly the throttle hold switch was on? its the switch on the top right side of the controller also theres a setup video for the align 35 amp esc on helifreaks site.
PA
I will check the site, no it was not the thottle hold that was on, this went into some type of programming mode for th esc..I will check the link thanks alot.
