Digital Tachometer
NC
Folks,
I'm looking for a upgraded digital tachometer. The one I have used you have to hold 4 to 6 " away from the blades. I'm building an 600N PRO and I'm not getting that close to these blades..
Any Suggestions?
RC-Shamus [sm=shades_smile.gif]
Any Suggestions?
I dont have a Tach yet i just do the math and that close enogh for me
and fly by feel to
oh i do have 1 for my planes but would have to be to close to the rotors to use it on helis
and fly by feel tooh i do have 1 for my planes but would have to be to close to the rotors to use it on helis
TX
rstroup: For a beginner, no. Not necessary at all on a 450 IMO. You can just run a proven motor+battery+pinion+blade combo that you know works, and also assume you get headspeed roughly the same to what others report with the same combo.
However, if you want to set up a Govenor mode on your ESC correctly, you MUST have a Tach to do it.
Also, if you start to do any competing, etc., you will certainly want to know exactly what your HS is for sure
NC
I understand that for a 600N if the head speed is to high or if the Blade angle is to low (Flat Pitch) you can burn out the clutch while you are setting it up. The tack for my V2 just helps me take the guess work out of the equation. Its not a must but it sure helps take out the guess work!
Cheers
Cheers
MD
I understand, for now I have enough on my mind. I have only hovered once, and I am finishing up rebuilding the head now. It is raining here so I cannot get out and fly until tomorrow.
