Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 3S TP battery conversion >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 01-06-2008 | 03:12 PM
Default 3S TP battery conversion
Greetings everyone. I just bought a 2100 Mah 3S thunder power lipo. The other battery I have is a mega power 2100 mah. My balancer/charger does not fit the thunder power connector for the balance lead. Can I convert the thunder power balance lead to a lead like the mega power battery? They both have 4 wires but use different colors and the thuder power pins are closer together than the mega power pins. Any info would be great.
Old 01-06-2008 | 03:45 PM
Default RE: 3S TP battery conversion
You should be able to get an adapter cord from your balancer supplier.
Old 01-06-2008 | 09:22 PM
p01rogue's Avatar
I have a conversion adapter that fits between the tp batt and your charger.
I don't need it anymore and will send it to you cheap.
Old 01-07-2008 | 12:29 PM
I did find one of my local club members that has one but thank you so much for the offer.
