Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 Bad motor or ESC? >
Bad motor or ESC?
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Bad motor or ESC?
Old 01-08-2008 | 06:44 PM
rockhouse's Avatar
Default Bad motor or ESC?
Was flying my rex yesterday when the motor stopped mid flight. landed. Checked & had a wire going to the motor broken. Fixed. Put back in the air for about 1 minute. Quits again. This time no broken wire, but it acts the same (kind of surging but won't turn). Is it the speed controller or the motor?
Old 01-08-2008 | 08:15 PM
jaketrouble's Avatar
Default RE: Bad motor or ESC?
sounds like the esc has gone bad.. i had the same problem.. so i took the esc out of another bird i had and tried it and it worked fine.. my problem was the blades would spin up real good at first and then slow down to a complete stop.. jake.
Old 01-09-2008 | 06:19 AM
Could be either one, if you have an extra esc try that first. I had the same issue and swapped out my esc cause I had an extra layin around but that turned out not to be the issue, it was one of the wires inside the motor case that was bad.
