Balancing Tail Blades?
KS
T-REX 450.
Is it important?
Do You do it the same way as the main in which You find the C.G first or just simply tape the lighter one on the outer edge and leave it at that.
I know they rev up pretty fast, so I was thinking it wouldn't hurt.
Gary
Is it important?
Gary
KS
Okay, good.
Won't bother, (I'm getting closer and closer to being finished, but the hardest is yet to come).
Thanks. . .
Thanks. . .
MD
I have not seen any posts explaining that this is important. Now if you crash, make sure you have not bent your shaft, because replacing the blades may not be sufficient.
