Trex 600 canopy
I just put together a new trex 600 and found that when I installed my fiberglass canopy it rubs against the main gear. Does anyone have any good suggestions on how I could fix this issue.
It dosen't mean it is correct but I would have had the same reply! {some one could have needed a canopy in a pinch and swapped it out with a nitro canopy by mistake} Mine has a 1/4'' clearence on both sides after it is pushed on the gromets which are 1 5/8 long and 5 1/4 tip to tip and has a buldge for the gear on both sides.
Jerry
Jerry
Thanks Jerry, I'll have to check into it in more detail later. One side hits and the other side is clear. Might just be a defective canopy.
