Heli P0RN!! Topless T-Rex 450!! mMMmMMmm
FL
So I rewired my T-Rex450 last night and did a quick reset of my swash and head (found and correct a minor problem with midstick not giving me 0 degrees of pitch). So This time I tried to hide as many wires from plain sight as I could without compromising anything or having to use that nasty (my opinion) wire loom. The result is all in the pictures.... Enjoy
TX
RE: Heli P0RN!! Topless T-Rex 450!! mMMmMMmm
Verrrrry Pretty and very clean looking!
Nice job on hiding the wires.
I am goin to try to make mine as clean looking with yours as a go-by.
I have a question,
I just bought a DX6i and can't get the box set up to work right like my former DX6 box.
could you post your DX6i settings please?
thanks.....
I have a question,
thanks.....
FL
All I did was copy my DX6 settings down on a piece of paper and transferred those into the DX6i. The one thing that threw me off was the swash mix. In the DX6 they refer to the different servos as CP1, CP2,and CP3. Whereas the DX6i calls them out by name AIL, ELE, PITCH. Also on throttle and pitch curves the DX6 gives you 3 points where the DX6i gives you 5. IF you are using a linear pitch curve, then 0 50 100 becomes 0 25 50 75 100. You have to extrapolate the middle number by hand.
But for the sake of reference, here are my TCs and PCs:
Normal Mode Throttle Curve
0 40 85 90 100
Stunt Mode Throttle Curve
100 90 85 90 100
Hold Mode Throttle Setting
0
Normal & Hold Mode Pitch Curve
30 40 50 75 100
Stunt Mode Pitch Curve
0 25 50 75 100
0 40 85 90 100
100 90 85 90 100
0
30 40 50 75 100
0 25 50 75 100
