GY240 setup
GY240 setup
i have a trex450 and it is not possible to adjust the servo - gyro. the GY401 has a screw for adjusting the travel of the servo so in the 240 how can i do it?
RE: GY240 setup
Set it to rate mode.
Get a blank wheel.
Figure out where on that wheel you could drill a hole that would make the linkage 90 degrees to the linkage, and get full travel of the slider without binding. Drill a hole, mount a ball, center the slider, flip the dip switch to AVCS and fly happy.
Get a blank wheel.
RE: GY240 setup
Thanks for the tip, but in rate mode everything is just fine, in the HH mode if i give full right rudder the gyro gives more. With the tip you told me this will be fixed?
