Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 Anyone using the Hyperion EOS 0606i? >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 07-23-2008 | 09:32 PM
Default Anyone using the Hyperion EOS 0606i?
I just got mine today, but I may be taking it back.
1. There is absolutely zero info on the net about it aside from the media link, but there is no support. I just can't find it.
2. It charges my 5000mAh 6S1P at 2.1A since the charge rate is based on mAh rating. According to the manual it would be charging well over 4A, but apparently that's not the case.
Maybe it's me and I don't have much time with this Hyperion charger yet. The pack voltage was 22.8v when I started charging, maybe it takes pack voltage into account as well. Still, the 2.1A rate never changed all the way to full charge.
Anyone have experience with these chargers?
Old 07-23-2008 | 10:09 PM
Default RE: Anyone using the Hyperion EOS 0606i?
Nevermind, I found out it's only a 50W charger, so it won't charge anything over 2.1A even though the manual says 6A.
Taking it right back to the LHS tomorrow!
Old 07-24-2008 | 01:43 PM
It will charge up to 6 amps. Or 6000mAh
Old 07-24-2008 | 06:15 PM
ORIGINAL: []TEX[]
2.1a would be a charge rate of 1c for the pack of 2100 MaH. most battery manufacturers don't recommend over that value. A 6000 ma pach should charge a 6.1 or 1C. Un less I am mistaken. Take it back for sure. I use the Cell pro chargers and I can assign the rate up to blowing up in my face and burning the house down or let the unit choose the best charge rate based on the packs needs. Remember it is trying to balance also. I am well pleased with my chargers.
Tex did you get your bearings yet?
Jim
Old 07-26-2008 | 12:33 PM
Got em yetserday.
All my packs are 5000mAh 6S so waiting 2.5 hours to charge is not an option...
