T-Rex heli For all you T-Rex lovers out there, this where you can post!
Trex250 problem
Old 01-19-2009 | 09:12 PM
Default Trex250 problem
Hi there,
I'm new to electric helis, I bought the trex 250 super combo and I placed my futaba 7C 2.4 Tx in it, but there is no response and the Tx keeps blinking, when I unpluged the ESC from the the Tx and conected the battery directly to the Tx everything worked fine, also the ESC gets very hot, does that means that the ESC is not working? please help.
Old 01-20-2009 | 07:19 AM
exeter_acres's Avatar
Default RE: Trex250 problem
have you "bound" the rx to the TX? using the easylink function?
Old 01-20-2009 | 08:38 AM
this is problem about BEC function in your ESC.. to make sure this is real.. switch to other ESC if new one work...that is your ESC must need to set BEC voltage to lower ... see manual
Old 01-20-2009 | 07:49 PM
visit this page... have many tips and problem solve method
http://www.runryder.com/helicopter/t485986p1/
