T Rex and DX6I Binding Problems
Hi New to TRex 250
Trying to bind DX6I (also new) to AR6100e on TRex 250 when bind complete and bind plug removed the ESC starts beeping maddly also the motor will not respond swash at wierd angle but think i have not set up reverse and swash mix any one got settings for DX6i AR6100e and Trex 250 settings
Main concern is the ESC beeping and no motor responce after what looked like succesful bind
Thanks for looking
any help appreciated</p>
My Feedback: (41)
Well I'm not an expert on dealing with electric powered setups, but I'll tell what I do with my little T-Rex 450; since there is nothing plugged into the Batt/Bind port on the rx, I leave a short extension plugged in there so I can get to it without a bunch of monkey business. I use that extension along with a Spektrum (three wire) switch and another regular rx pack battery, to power the rx/servos, set travels and do rx binding. This takes the ESC out of the loop and I don't have to worry about the motor spinning up or anything as well.
You may want to give the separate battery method a try for binding purposes????
