T-Rex heli For all you T-Rex lovers out there, this where you can post!
Need some Help!!
Old 12-05-2009 | 07:18 PM
My Feedback: (9)
Default Need some Help!!
I am putting a 450 together with JR servos and a JR gyro. The package came with a Spektrum AR6000 reciever and I have a JR 9303 2.4 radio. Will the AR6000 work with the JR servos and 9303 and if so How do I plug in the servos?
Old 12-05-2009 | 08:15 PM
Default RE: Need some Help!!
Shouldn't be any problems. Plug the lead from the ESC into the THRO channel, right front or aileron servo into AILE, rear or elevator servo into ELEV, the lead with 3 wires running from the gyro goes into RUDD, and the single wire lead from the gyro goes into GEAR. and the left or pitch servo goes into AUX1. Alan
Old 12-05-2009 | 10:18 PM
My Feedback: (9)
Thanks everything is working fine. I was remembering the old days when AIRTRONICS and JR could not mix.
Old 12-06-2009 | 06:39 AM
The only things you have to pair together is radio with receiver, especially if using 2.4 ghz. Those must be same brand. Other brand servos and gyros, ESC, etc. will work with any brand receiver/radio. Some gyros will only work with certain servos though. Alan
