Trex 550e 3G build and discussions
#51
FL
RE: Trex 550e 3G build and discussions
ORIGINAL: CSpaced
Just curious how you had the head set up incorrectly? I'm looking forward to getting mine in a few weeks!
make sure your head look like this.
#52
FL
ORIGINAL: CSpaced
Thanks for the info noobflyer. I've been debating which battery to get for mine, and more importantly - where to get it from?...
NP. I'm using the turnigy's 5000mah 6s 40C packs. Igot mine from a US vendor for $140. At HC you can get them for $99 plus shipping. Wait time is around two weeks as these are over seas.
#54
FL
Hey Hollywood, the 550E is doing great. I'm tweaking it out but its getting very close to perfect. I'm uploading the lastest video now. stay tuned! There's some serious power here.
#55
FL
[youtube]http://www.youtube.com/watch?v=l9ys0OhqDeQ[/youtube]
I just change some settings on the 3g controller after this flight:
aileron total gain compensate 45
roll lock gain adjustment 45
elevator total gain compensate 45
elevator lock gain adjustment 45
rudder total gain adjustment 50
rudder lock gain adjustment 50
increased 5 points on hiller rate now at 45
decreased 5 points on bell rate now at 75
all other settings are stock.
#57
FL
ORIGINAL: TCipolla
does this thing run 6S?
#59
FL
ORIGINAL: CSpaced
Interesting that you have a blue swash, mine has a black one. Was it stock?
Ijust ordered the CC ICE100a for my heli. Iwill be running this bird on 2500rpm governed.
#60
FL
This heli is a beast. I just love how you can tune the heli to suit your style. very cool. Flys like its on rails! Look Ma, no more wobble!
I just sold off the stock esc and will install the CC ICE 100a when it arrives on Wednesday.
[youtube]http://www.youtube.com/watch?v=hWcXrb1wJwU[/youtube]
#61
MI
Good move on the ESC. Saturday, I blew a Castle ICE75 on a different helicopter, but I ordered a 100 ICE Monday. Ithink I blew it because I put a Scorpion 4020 1100kv in the helicopter and regeared for at least 2600 rpm on a different brand of 550. Wasn't pretty.
I love how your bird is flying, T!
Scott
Scott
#62
FL
ORIGINAL: dunkonu23
Scott
Scott
Ijust installed the ICE 100 and did a flight on it . [youtube]http://www.youtube.com/watch?v=T_OG33Au1h0[/youtube]
here's the CCdata log.
I still get a very tiny amount of tail wag. Ithink go to a better tail servo will fix that problem. just another excuse to upgrade.
#64
FL
Thanks Hollywood. I'm really liking it now. It flys real BIG and has gobs of power at your disposal. I"m upgrading the tail servo next and get more batteries and I'm set.
Compared to the Trex 500, the 550 flys much bigger and feels very stable. With some tweaking to the 3G it works very well.
#65
MI
Wow... 158 Amps max... wow... just wow. Stunnning. Kinda makes me think I did good with the 100, too. I won't know soon, though... I found a broken servo mount today and the replacements have to be ordered from Qatar.
Scott
Scott
#66
FL
I Got the DS650 yesterday and installed it.
Align DS650 Digital Servo
Stall torque:4.0kg.cm(4.8V)
5.0kg.cm(6.0V)
●Motion speed:0.058sec/60°(4.8V)
0.048sec/60°(6.0V)
●Rating voltageC 4.8-6V
●Temperature range:-20°C~+60°C
●Dimension:40.3 x 20.1 x 36mm
●Weight:56g
●1520μs standard band
●Ultra-speed servo for instant tail control reaction. (0.048sec/60 deg).
●12 Bits 4096 signal resolution for smooth movements.
●Ultra Performance Coreless Motor with fast reaction and low current.
●Hardened high strength superalloy gears that increase the lifetime.
●Aluminum alloy mid case construction for instantaneous heat dissipation, maintaining servo’s high efficiency.
●Supports digital & analog control signal.
●Powerful and precise servo, suitable for T-Rex 600/700 rudder use.
5.0kg.cm(6.0V)
0.048sec/60°(6.0V)
●Weight:56g
#68
FL
ORIGINAL: dunkonu23
Any difference, T?
Scott
Any difference, T?
Scott
#69
FL
ORIGINAL: dunkonu23
Any difference, T?
Scott
Any difference, T?
Scott
just tried it out today. one word comes to mind. Awesome! very fast and crispy tail. This video is the very first flight after the install of the DS650.
[youtube]http://www.youtube.com/watch?v=iw96vzOc2yg[/youtube]
#70
MI
Awesome is about the only word I can think of, too! Outstanding is another word, but that's for your flying. Wow is another word. That's it.
Scott
Scott
#71
FL
thanks Scott. that's quite an ego booster Still getting comfortable with the FBL thingy, then I'll try out some new moves I've been practicing.
#72
MI
Trust me, T... you deserve that and more. Your skills have really grown a lot. I'm more than impressed, sir. I'm kind of torn betwen a Gaui X5 and the T-Rex 550 FBL version. I have until IRCHAto decide, but something in me is tugging toward the T-Rex.
Scott
Scott
#74
FL
I got in another flight this morning. More of the awesome goodness I'm still reluctant to try out new moves for the fear of crashing. I want to have a good amount of flight time with it before I walk down that path. She's just too pretty.
