RCU Forums
-   T-Rex heli (https://www.rcuniverse.com/forum/t-rex-heli-435/)
-   -   esc programming (https://www.rcuniverse.com/forum/t-rex-heli-435/10176850-esc-programming.html)
mikemscott 12-05-2010 12:30 AM
esc programming
If you've purchased an esc with out a programming card are you dead in the water, or can these still be programmed? I purchased awhile back not sure where i purchased from. Is there a way to program without the card. Its a 30 amp for450 heli. I don't know the brand can't read label. Can it be programmed thru the DX6 without card? Thank You, Mike Scott, [email protected]
jfast 12-05-2010 11:13 AM
RE: esc programming
i would look online for a manual for your esc. most esc's will work at whatever default they are set at. I have several planes that I have never programed.
Cleared2Engage 12-05-2010 07:10 PM
RE: esc programming
If it's flying fine then I wouldn't even touch it. If you're having trouble with it, post a picture maybe there is someone here who could identify it. Then that'll get you on your way to searching for a manual online.
