RCU Forums
-   T-Rex heli (https://www.rcuniverse.com/forum/t-rex-heli-435/)
-   -   esc problems please help (https://www.rcuniverse.com/forum/t-rex-heli-435/6055026-esc-problems-please-help.html)
ground killer 06-30-2007 03:09 PM
ok guys hear it is i have on board
1 electrifly 11.1v batt
1 align esc, rce-bl35g
1 futaba pcm 1024 r146ip rx
and of cours the servos
i fallow the direx to get the bec/esc to detect the rx in user mode and setup mode and all i get both ways is the first 3 tones and thats it my gyro blinks but nothing else what am i doing wrong
i know the battery is fully charged and the tx is on i have even tryed to get it to go without the tx on but no good please help
exeter_acres 06-30-2007 03:26 PM
RE: esc problems please help
your post is really dificult to understand....
but...
have you reversed the throttle channel on your radio?
ground killer 06-30-2007 03:51 PM
how do i do that
ground killer 06-30-2007 03:56 PM
to make a long story short my esc doesnt detect my rx or enter setup mode what is going on
jeff1962 06-30-2007 04:42 PM
If you are trying to setup the esc you need to have a linear throttle curve with 0 at low stick 50 at mid and 100 at high stick, put stick to high position wait for the confirmation tone then put stick to low and wait for confirmation tone, you will then be in setup mode. If the esc cant detect full stick throws it wont setup.
ground killer 06-30-2007 05:05 PM
check pm
exeter_acres 06-30-2007 05:11 PM
if you are using a Futaba TX then reverse the throttle channel before you do anything else....
really....
jeff1962 06-30-2007 05:35 PM
on futaba radios channel 3 is for throttle if it needs reversing find reverse in the menu and flick it over, also go into end points on the radio and make sure ch3 is at 100% on both ends.
Georges Payne 06-30-2007 06:19 PM
AND make sure that you remove the pinion gear from the motor before attempting to adjust the ESC. It can go to full throttle at anytime. A good thing that my T-Rex was securely tied down to a large 2x8 or it would have taken off on its own while I was experimenting.
Be safe!
Georges
ground killer 06-30-2007 07:48 PM
ok im using the futaba 6exhp tx the book says that chanel 4 is the throttle so that is were i put the esc wire on the rx as far as the settings goes that will have to wait i still cant get the esc to make contact with my rx so is my brand new esc bad.........................still flying in the dark if you know what i mean lol
cflight 06-30-2007 10:14 PM
The throttle settings will have alot to do with the ESC initializing and entering program mode. Double check to be sure that everything is plugged in with the correct orrientation, ground-ground and signal-signal, positive is always center.
For more help, check out the vids available at helifreak, http://www.helifreak.com/viewtopic.php?t=12455 the particular vid, will be ESC set up vid and give you a conformation as to sound Qs from the ESC.
ArrowNaughtic 07-01-2007 02:31 AM
ORIGINAL: ground killer
My 6EXH has ch3 as the throttle and ch 4 as the rudder...................... You need to look at your servo and ESC connections again. You have the ESC plugged into your rudder channel. On the front of your TX just to the right of the led display mine has all the channels marked.
Ch 1 - Aileron
Ch 2 - Elevator
Ch 3 - Throttle
Ch 4 - Rudder
Ch 5 - Aux/ Gyro
Ch 6 - pitch
Thats the T6EXHP model............. I am assuming you have the same one. You must have a typo in the manual. Hope that helps a little.
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
