Can you loop or roll in normal flight set up?
Just wonderning seem to be getting pretty close on the loop. Not ready yet for 3D set-up
RE: Can you loop or roll in normal flight set up?
Yes...you can loop...but give yourself some serious altitude before trying it.....
go ahead and set up idle up...it is easy |
ya, but set up so stick down gives you negative pitch. Get some good altitude, and go into forward flight. When your coming back from a circuit, just pullup. Once your inverted pull the stick all the way down, then when your back up again. Continue with normal flight. Its really a simple manuever. I have been flying helis for about a month now and i can do all that fun stuff with my copter x (trex450). Iv gotten to the point were i can do most 3d stuff at low altitude and still havnt crashed once. Just take your time. Me, i fly about 20-50 times a week, just go slow and unlike the planes and cars, don't push yourself to hard. For me, i just don't have the experience to put the thing back to gether correctly, nor the funds to fix it. After just spending 2 grand on this setup, its gotta last me.
As for rolls, you must have negative pitch for the inverted portion of the roll or else you'll actually end up doing a horizontal loop.
ORIGINAL: bbike ya, but set up so stick down gives you negative pitch. Get some good altitude, and go into forward flight. When your coming back from a circuit, just pullup. Once your inverted pull the stick all the way down, then when your back up again. Continue with normal flight. Its really a simple manuever. I have been flying helis for about a month now and i can do all that fun stuff with my copter x (trex450). Iv gotten to the point were i can do most 3d stuff at low altitude and still havnt crashed once. Just take your time. Me, i fly about 20-50 times a week, just go slow and unlike the planes and cars, don't push yourself to hard. For me, i just don't have the experience to put the thing back to gether correctly, nor the funds to fix it. After just spending 2 grand on this setup, its gotta last me. |
ORIGINAL: hennesseylord ORIGINAL: bbike ya, but After just spending 2 grand on this setup, its gotta last me. It must be a Falcon 3D with all the SE upgrades ..............(He, He ) Harry |
TheBum
You don't have to have neg. pitch for a roll. If you going fast enough and start the roll once passed 90deg then reduce the throttle stick to half (ie hover setting) and keep the momentum it will do a full roll. It ain't pretty ill give it that but it can be done and i do it. dtacmed Not sure why you would want to do these maneuvers with out neg. pitch but the loop can be done well. Once again get good fwd speed and height, once passed the 90deg mark back the throttle off to half stick and your good to go. Be careful not to back the throttle stick off to much though. Let us know how you go it is a lot easier than you might think, once you have done it you'll be asking yourself why you hadn't done it earlier |
well, new radio, and 10 2100mah 3s lipos, it adds up. I didnt even get the real trex, i got the copterx and i still spent that much. fly AMAZING though, flys like the raptor 90 in realflight g3.5.
10 lipos?! You must have some marathon charging sessions.
ORIGINAL: exeter_acres go ahead and set up idle up...it is easy If you are above a basic hover, and you are flying outdoors, idle up is where you should be. Vince |
I have the greatplanes poly charge and the duratrax ice charger, so I can charge 5 lipos at a time. I can go to the field, fly five packs, let them cool. Throw them on the charger and by the time i finish the other five packs, i only have to wait about a half hour till i have another five packs and then repeat! Its great, since im the only one of my group that flys helis, every one else does the nitro planes (which I do to) i can litterly fly for hours. Plus, my 3s 2100 packs also work great in my greatplanes extra330s so i can fly the planes and helis, and when the batterys are charging, i put out the good old slimer, or rc cars. I got it made[8D] lol.
ORIGINAL: VinceHerman ORIGINAL: exeter_acres go ahead and set up idle up...it is easy If you are above a basic hover, and you are flying outdoors, idle up is where you should be. Vince Vince, What you are saying is that it will ba alright to go idle -up even on a hoovering mode. Thank you. |
Yes, idle-up is good.
I did a lot of indoor hovering with my T-Rex when it was new. Too much snow to do much outdoors. But when I did go out that spring and fly outdoors, I had a heck of a time. I would baloon up every time the wind blew, and getting it back down from altitude meant lower head speed, and less cyclic control. Brother #1 said that idle up would take care of that. So we programmed it there at the field, tested out the transition from normal to idle up at a safe altitude (yes, it jumped up when I hit it the first time) and then experimented with the different feel, even just hovering. It was night and day. The heli had full cyclic control at all times. After a few cycles of testing and adjustment, I got it tuned close enough that I could flip the switch back and forth and not see the heli do more than the slightest twitch. Some times I switch in the air. Some times I switch on the ground. Yes, even in hovering, idle-up is good. Vince |
Vince,
Thank you very much for your reply. One more question. Any suggestions on what would be a good idle up values. My T-rex's idle up values were base on Finless Bob's video but never tried it yet. Thank you. |
what motor are you using? on the align motor, i use between 75-85%
Finless videos are great and for sure you can start with the numbers posted in those videos (Maximum and minimum pitch clearances), with some experimentation time you may change the settings to your very personal choices just keep in the pitch window between the minimum and maximum parameters. I am really new in the Heli hobby I have been flying RC Planes for years and mechanics are some quite different but very understandable and I have set the Idle 1 with no problem although I have not used yet because of my limited skills by now.
Have Fun!! |
Thanks for the replys I know I need to set up idle up still nervous with the 600. I'm flying around some fast forward just need to do it I guess
Continue with normal flight. Its really a simple manuever. I have been flying helis for about a month now and i can do all that fun stuff with my copter x (trex450). Iv gotten to the point were i can do most 3d stuff at low altitude and still havnt crashed once. |
| All times are GMT -8. The time now is 02:08 AM. |
