RCU Forums
-   T-Rex heli (https://www.rcuniverse.com/forum/t-rex-heli-435/)
-   -   First bad Crash! (https://www.rcuniverse.com/forum/t-rex-heli-435/7050366-first-bad-crash.html)
AAVN60 02-09-2008 08:32 PM
First bad Crash!
well today I had my first over $100.00 crash, sucks but I already ordered the replacement parts! Has anyone ever broken the motor in a crash? well I did today. rotor blades, Main gear(only the top one), skids and cross tubes, banged up my canopy a little, bent flybar, bent feathering shaft, and sand everywhere in the bearings. Is their a way to program the DX7 so I can have a cutoff switch for the power? Thanks in advance!
-Justin
matador_24 02-09-2008 08:47 PM
RE: First bad Crash!
Welcome to my world, over 800dlls in spare parts in 5months of flying [&o] (I know)
I think the only thing I haven't broken is the motor :D good luck rebuilding!
joediamond 02-09-2008 08:58 PM
ORIGINAL: AAVN60
-Justin
That's what the throttle hold switch is for.
AAVN60 02-09-2008 09:19 PM
yeah thanks!, Throttle switch, um I know i've seen it but can you briefely explain how it works?
matador_24 02-09-2008 09:25 PM
in the DX7 is the upper-right switch of the Tx (it says HOLD I think in small).... when is ON, the current cuts off and the motor stops spinning, that will save your main gear if you switch it right before crashing., no matter where your throttle stick is, while the HOLD switch (autorotation) is ON, the motor won't spin, servos and gyro will work, that is also used to do autorotations.
AAVN60 02-09-2008 10:14 PM
oh very cool, did not know that, would have saved me a bunch of money today! the belt sliped off the pinion when I was in a stalling turn, the rest was history, lol
