flight time?
just curious,, I guess about 8mins. is normal for flight time, newbie question, for just hovering around, just trying what will be best to set on my radio
RE: flight time?
depends on your setup. motor , esc, lipo, headspeed, pinion , blade size, the list goes on and on. what are you running with? i have a trex450sa with the align 430xl and align 35x with the justGOFLy 450F with 11t pinion and the 325 blades, with the thunderpower 25c 2200mah I will get 3000 rpm with 5 full minutes in idle up. in normal i will get 8 minutes max.:D
RE: flight time?
430L; 35G ESC; TP 2200 25C; 11T; tached at 2760 rpm at 0º pitch/82% throttle center stick; +10/-10 range, th curve 98 88 82 88 98.
I have the DX6i's chicken timer set to 4 minutes. I fly for 4 minutes, land. Make adjustments if necessary, fly for 4 more minutes. LVC, set to 9.6V, never kicks in. It will kick in if I go about 1½ - 2 minutes over the timer. |
RE: flight time?
Sounds about right, I guess I just need to buy a 1/2 doz. batteries if I want to fly for more than a half an hour.
RE: flight time?
I have the 450 SA also. Run parkflyer 2200 mah batteries, with mild set up runs about 8 min. I newbie also. Currently flying hover all orentations ff. small banked turns. lot & lots lots of practice
| All times are GMT -8. The time now is 02:35 PM. |
