Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
OS 61FX with pipe
Old 11-13-2003 | 03:35 AM
Jon Wold's Avatar
Default OS 61FX with pipe
Turning 10.300 RPM on 15% nitro castor/synt mix fuel.
APC 12x10 with Goldberg plastic spinner.
JustEngines purple pipe and header (Three-baffle Hatori replica), standard length.
Might just make 10.000 with a 13x10 APC if I lengthen the pipe slightly
Old 11-13-2003 | 09:19 AM
My Feedback: (12)
Default RE: OS 61FX with pipe
That sounds about right for a 61FX but a YS 61 AR or a OS Hanno Spl both will turn about 1000 RPM more with the same prop/fuel setup.
