Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
moki 180 rpms
Old 07-23-2004 | 06:10 PM
Default moki 180 rpms
moki 180 bission pitts muffler no regulator, 8400 rpms, 17 3/4 lbs. on fish scale.
4 gals. 5% wildcat run in engine. pulls creek katana outa site. 12 3/4 lbs. Milage
is 12oz. in 10 min. Botta bing botta boom. 18-10 ma.
Old 07-23-2004 | 06:43 PM
Default RE: moki 180 rpms
Do you have a propeller on it?
What size?
Old 07-29-2004 | 12:30 PM
coveredup's Avatar
What size?
ive done that before, i had to go back and re edit my tach readings
Old 07-29-2004 | 12:37 PM
Shortman's Avatar
My Feedback: (21)
Try 0% Nitro, or FAI fuel and note the difference.
Old 08-01-2004 | 07:15 AM
Several tachs used on it. Does is run better wih 0% nitro? Only had 5% in it since new.
Have had no problems with the Moki 180. I fly half throttle, all it needs unless you want to get to the moon faster.
Going to try a Menz 18/8 , will slow rpms down some I think.
Old 08-06-2004 | 02:42 PM
tonyc's Avatar
I use the Menz 18x10. I didn't tach it but I think the 18x8 would be a little fast for you. In the Bambula line I use the 18x8. The Bambula is a slower prop and gives you about the same verticle as the 18x10 Menz.
tonyc
Old 08-08-2004 | 06:49 AM
Will a Menz prop have more pull than a APC of the same diameter and pitch?
Also do you think a Bambula has more pull than a APC or Menz?
Thanks tonyc,and all for the replys.
Old 08-10-2004 | 09:19 AM
tonyc's Avatar
Wood is lighter than plastic. So the Menz would spool up quicker.
The APC is a good prop. I have the 20x10 APC wide on a Moki 210 and its a good prop. I bought this because I couldn't get the Bambula prop in the same size so I bought a prop grom the LHS.
I tried the APC 18x6 wide on the Moki 180 and this didn't work for me. Too much rpm not enough pull.
The Menz Ultra is also a good line of props. I like wood a lot so I stay away from plastic.
tonyc
Old 08-23-2004 | 04:40 PM
Cheech's Avatar
My Feedback: (19)
I run the 19x8 Mezjlik prop on my Moki 1.8 and it turns at 7750RPM. The engine runs fantastic, transitions flawlessly and pulls like a mule.
Old 08-24-2004 | 04:17 PM
Anyone tried a 20-6 prop on the moki 180? What rpms did you get?
Old 09-09-2004 | 10:47 AM
carlbecker's Avatar
I have a Mezjlik 20x6 giving a rich 8800 rpm and 19x8 at 7900 rpm. Using Byron 5%
Old 09-20-2004 | 07:31 PM
Thanks for all the replies, lots of help.
Thanks, Kenneth
Old 10-24-2004 | 07:59 PM
Moki 180
APC 18x8
FAI Fuel
Bisson Pitts muffler
8600 RPM
18 lb on fish scale
model WM CAP 232 (vertical unlimited)
[img][/img]
