Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
What peop for a Sachs 3.4 engine?
Old 08-14-2005 | 03:54 PM
Skribnod's Avatar
Default What peop for a Sachs 3.4 engine?
Anyone else runnings a Sachs 3.4 engine? If so what prop size do you suggest for aerobatic flying? Also wood or APC since carbon fibre is too expensive at this time. Thanks
Old 08-19-2005 | 01:24 AM
paulsen's Avatar
Default RE: What peop for a Sachs 3.4 engine?
Alot of people at my field use a 20x8-14 and scimitar 20x10 on there sachs 3.2 I also have bolth props for mine in my Pitts S1. I would imagine a 3.4 should be very close, are you sure it's not a 3.2?
