Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Ryobi 35 CC
Old 10-22-2002 | 05:40 PM
My Feedback: (34)
Default Ryobi 35 CC
MAS 18X6: 7900 RPM
Old 10-24-2002 | 11:50 PM
Default under 9000 with a 35cc??
with a MAS 16x8 im getting around 9000 with my ryobi 31cc.
im starting to wonder if my globee tach is not working right.
Old 10-25-2002 | 11:54 AM
Default Ryobi 35 CC
A G38 turns around 7000-7200 with a Zinger 18X8. 7900 with a 16X8 sounds good.
Old 10-28-2002 | 03:14 AM
soarrich's Avatar
My Feedback: (98)
Default Ryobi 35 CC
I'm getting 71~7200 with a Masterairscrew 16x8. No mods other than cut down flywheel, stock muffler.
Old 10-28-2002 | 05:59 AM
My Feedback: (34)
Default Ryobi 35 CC
I don't know if the extra 800 RPM is worth all the work. I mod:
1. carby
2. Reed valve
3. Intake
4. Piston Ring
5. Head
Lots of work... I like the idea of just cutting down the flywheel and calling it a day.
Still, I have my 35CC Bully which smokes the Ryobi and weighs in under 3 lbs. The Ryobi is great for floaters.
Old 11-01-2002 | 02:35 PM
Default Ryobi 35 CC
Master Airscrew 18 X 6 at 7900rpm is right on for the stock magneto equipped Ryobi though I don't know of any 35cc Ryobi, I think we're talking 31cc. Anyway, to the gentleman below that's only turning a Master Airscrew 16 X 8 at 7000, something is wrong. You should be turning the Master Airscrew 18 X 8 at 7000-7200.
Old 11-01-2002 | 03:23 PM
soarrich's Avatar
My Feedback: (98)
Default Ryobi 35 CC
Ok, I'll retack my motor and recheck the prop size. It flies this 16 pound 88" plane fine though.
