Evolution 45 Power System
Carefully with APC 13 x 4 on evolution 45 PS.
I think that this propeller is too much for this engine.
The increase of propeller load increase the heat in the combustion chamber.
AZ
This is an Evolution Trainer A 45
Fuel: Byron 15%Nitro 18%Synthetic/Castor mix
67 degree F 2570 ft altitude 18% RH
About 3/4 gallon of fuel thru it.
Mounted on Alpha 40.
MAS G/F 3 11X4 14400
MAS G/F 3 11X5 13450
MAS G/F 3 11X6 12150
MAS G/F 3 11X7 10650
MAS G/F 3 11X7.5 10300
MAS G/F 3 11X8 9900
APC Scimitar 12X6 9450
The engine was still not broken in after 1 gallon as had to remove restraints to lean out idle.
Earlier after about a quart
H9 3 blade 10.5X4 10000
MAS G/F 3 11X4 13500
MAS G/F 3 11X8 9900
