Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
older OS 40 settings
Old 02-12-2003 | 12:26 AM
Default older OS 40 settings
Anyone know how to adjust the carb on an older OS 40? Any help would be mutch apreciated because i just cant get it. Is it my prop im using an APC 10x6?
Old 02-24-2003 | 07:44 PM
Default What OS 40
Please advise which OS 40 motor you have
Old 03-19-2003 | 12:13 AM
Default older os 40
I used to have an older os 40.. I tried 2 and 1/2 turns out from closed and started motor then turned in 1/4 turn at a time until the motor is running at peak rpm... you'll know this when, at full throttle, you hear the high pitch and the slightly lower pitch at the same time.
If the motor is run too lean, it will die if you gun the engine from idle to full throttle, if this happens open it back up a few clicks until it doesn't die anymore.
Hope this helps.
