Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
SC52 Tacho Reading
Old 02-28-2003 | 02:21 PM
Default SC52 Tacho Reading
Hi
The SC52 FS is my first 4-stroke. I am extremely pleased with it so far.
I ran through it 1 litre of 5% nitro/20%castor on the bench. It started first time, the needles are easy to adjust. Initially I ran it very rich but gradually leaned out to get good RPM.
Then I mounted it onto a Seagull Stearman bipe Inverted. Again it started first time even inverted when starting. The Tach Reading that I have is 92K with 11 X 7.5 prop.
Wonder anyone out there have similar engine but different prop Tach Readings.
Simon
