Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Engine tach readings
Old 03-19-2003 | 12:47 AM
Default Engine tach readings
Is there any engine in particular anyone would like a tach reading for? I have many different engines and if someone wants info on one just let me know. I will list off the engines I have.
OS Max: 25 fp, 40 sx, 40 sr (old), 46 fx (Brand New)
Super Tigre: 29 S, 40 S, 45 GS (7 years old), 45 GS (Brand New)
Saito: 45 FA (old), 56 FA (Brand New)
Rossi: 40 (Just Broken In), 45 (old)
Magnum: 40 (P.O.S.)
Can give tach info on any of them along with there run history, how much fuel is thru them and maintenance info. All were purchased new and ran only by me.
Old 07-21-2003 | 05:40 PM
yard-dart's Avatar
My Feedback: (35)
I just purchased a used Rossi 40 from a guy here on rcu. It is an older engine, probably late 80's model, but it is in good shape and has good compression. I ran the engine yesterday on a cougar and could only get around 12k out of it. I'm turning a 10-7 apc and running cool power 5%. Shouldn't I be getting a lot more rpm out of this engine? The overall performance of the engine and throttle response is good. I just figured it should run up a little higher than what I'm getting. I was told by someone here on rcu that this engine should only be run on 5% nitro but a guy I fly with said that over the years he has had many high performance engines and he has run higher nitro in them with no trouble. Could this engine possibly run better on higher nitro without having to shim the head? I'd like to be able to get a little more out of this engine if possible.
Old 07-26-2003 | 12:17 AM
My Feedback: (28)
Default ST45
Hi; I just bought a new ST 45 and I would like to know what kind of rpm's this engine gets in real life? What I need to do is buy a tech. HAHA. Thanks for any info..........Veco
