Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Mvvs .49
Old 06-03-2003 | 06:03 PM
Default Mvvs .49
Originally posted by MyAeromodelling
I
To further keep the engine in good condition, I have been using after-run oil each and everytime after end of the day. For me its better to have oil rather than nothing inside the engine for added protection.
The after-run is also owned blend ie 50% car gasoline fuel injector cleaner and 50% regular automatic transmission oil.
Based on my experience so far with the engine and what I believe is the most important thing to know about the engine is that ---- MVVS really performs best with a 0% nitro and less than 15% oil, in my case it is a 10% pure castor.
To keep the exhaust screws tight, use only metal-to-metal contact faces, and take care that all powder coat that might be present on the exhaust adapter flange is removed. I use no flange compound or anything else between the joint, and have not experienced leaks and/or loose connections.
10% oil is not recommended. You may get away with it for some time, and it is proof of the sturdy material combinations that MVVS uses. but I would recommend at least 15%, and even then, the engine must be run in well before using such a low oil content.
Feel free to call me old-fashioned :-).
Just plain automatic transmission fluid, (this is not transmission oil!), will do the after run job just as well. Some injector cleaning fluids will mix with methanol, and when blended to the fuel, will keep the engine clean inside.
Old 06-10-2003 | 11:00 AM
Default MVVS quiet muffler
I just came back from the field after puting an ultra-quiet muffler on my MVVS45. It hardly does 10K RPM with 5%, 10300 @ 10%, both with a 12X4. It also lacks a lot of power. I previously had the black tuned pipe on this engine, and it was much, but much stronger.
I moved to the quiet one due to noise restrictions in the field I am flying from.
I suspect the muffler limits the RPM to about 10K.
Any similar experience?
Ilan Barak
ISRAEL
Old 06-10-2003 | 01:17 PM
DarZeelon's Avatar
Default MVVS
Ilan,
Look earlier in the thread. It was on the .49, but the effect is similar. Also look at the messages from Jaka and Preivers.
It seems the #3245A quiet muffler robs the engine.
It causes a sharp fall in power.
Try using the #3248 tuned silencer that you have and add an expansion chamber after it. MVVS recommends adding a length of silicone hose to reduce noise.
Say what? A field in Israel with real, enforced noise restrictions???
Sincerely,
Old 06-11-2003 | 09:01 AM
Default Mvvs .49
Some more rpms
Mvvs .45 with 3245A muffler 11*5 apc @ 11000 rpm
Mvvs .40 with 3245 muffler 11*5 apc @ 12500 rpm
Mvvs .49 with 3245 muffler 10*7 apc @ 14000 rpm
the A type mufflers really robs the engine of 10-15% power. But it sounds very pleasant to the ears !!
Old 06-11-2003 | 01:07 PM
Default Mvvs .49
Originally posted by bobi
Some more rpms
these are very usable data.
Some tests of my own to regain a few hundred rpm.
The A-type muffler can be dismantled into parts by removing the three screws, filing off the crimp,and slowly heating, until the epoxy gets soft.
Carefully wiggle the added damper off.
Ream the exhaust outlet out one millimeter. This compensates for the higher back pressure in the added chamber.
Using a 30 degee cone punch, form a bell mouth on the inner side of the stinger pipe.
With a suitable rat-tail file, ream the stinger pipe about 0.5mm.
Using liquid metal (market dependant), glue back the added damper, well lined up, and screw tight while the glue is still uncured.
After these mod's the exhaust note still is very agreable, and power loss is very much reduced.
Field data:
Engine .21 mvvs, MA 8x5 (1/12 combat, 85/15 fuel, no nitro) 16400 -16.600 rpm with standard 3235 muffler
This is ~500 rpm in excess of ACES regulations.
The modified 3235A-type muffler turns just around the limit of 16000 rpm (pinch-peaked, cold, 16.200, very hot 15.890) A silicone deflector will take care of the extra 100 rpm.
Noise is very much reduced by some 5 dB(A); it was 84 dB with the 3235, now it is 79 dB at 7 metres (77dB with non-modified 3235A-muffler)
Old 06-11-2003 | 01:27 PM
  #31
DarZeelon's Avatar
Default Power reduction percentages
Some more rpms
Bobi,
Since horsepower realized on a given prop is to the RPM in the third power, if your engine turned 12,500 RPM and with the new muffler it turns only 11,000 RPM, It has lost roughly 32% of its previous power.
This is a much more acute loss than it sounds at first, not 10-15%.
Sincerely,
Old 06-12-2003 | 06:03 AM
  #32
Default Mvvs .49
Preivers
if you have a picture of the modified A type ( before sealing the added chamber )......... it would be great.
i was thinking of removing a part of the inner exhaust and sealing the added chamber back.??
