Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
SIG Aviastar .46 From Aviatronics
Old 07-07-2009 | 01:34 PM
  #51
jeffie8696's Avatar
Default RE: SIG Aviastar .46
I have been meaning to ask , what is the idle speed that most consider to be an acceptable minimum? Isn't it going to be dependent on many factors like prop pitch, airframe drag and weight, field conditions? It seems everyone is shooting for 2000 rpms. However it seems to me that most engines will idle more reliably closer to 2500. I have found on rare occasion some that will idle at 1800 but most depends on the carb setup. For example a 10X6 at 2000 says 9.9mph but only .11 lbs of thrust , a 10X5 is 8.2 and .1 lbs, 10X4 6.6 and .09.
Old 08-07-2009 | 01:35 AM
  #52
faulknej's Avatar
My Feedback: (9)
Jeffie, what mount are you using on your .46? It's so much bigger than my .40LA. Won't even fit between the arms of the OS mount.
Old 08-13-2009 | 02:32 PM
  #53
jeffie8696's Avatar
Sorry so long getting back to you. The only mount Ihave for this engine is an adjustable one Ibelieve it is a Dubro. But any mount designed for the OS46SF should work.
On closer examination Ibelieve it may be a Great Planes adjustable.
Old 08-16-2009 | 08:15 PM
  #54
faulknej's Avatar
My Feedback: (9)
Ihave the GP mount also. 40-70 size. Ihad a heck of a time drilling the holes for it, as the muffler mount sticks so far out over the mount holes. Finally drilled it upside-down then turned it over to mount it. I measured the width of the mount with the engine bolted on, and Icouldn't mount it in my 40 size trainer if Iwanted to. The firewall isn't wide enough. lol I hope my Tiger 2 (which arrives tomorrow) has a wider firewall. I'd hate to have to modify the whole nose to mount it.
I'm still breaking it in, 4 tanks through it, it's still tight at the top.APC 10X8, Cool Power 15% with castor added to 25% oil, Merlin hot plug.
Old 08-16-2009 | 08:22 PM
  #55
jeffie8696's Avatar
The AV engines are not dainty. But they are built to dish it out and take it. That is why they have been packaged with trainers.
Old 08-16-2009 | 08:25 PM
  #56
faulknej's Avatar
My Feedback: (9)
ORIGINAL: jeffie8696
Iagree about the "not dainty". Seems to have a lot of power though. Igot 12200 with it still very rich.
Old 08-16-2009 | 08:34 PM
  #57
jeffie8696's Avatar
Ihave no complaints whatsoever about the power.
Old 08-16-2009 | 08:36 PM
  #58
faulknej's Avatar
My Feedback: (9)
I'm going to fly it on 5%. You recommend removing the shims?
Old 08-16-2009 | 08:44 PM
  #59
jeffie8696's Avatar
Only you can determine that. Test and tune.
Old 08-17-2009 | 10:03 AM
  #60
bigedmustafa's Avatar
I'd be surprised if you had to do anything to an Aviastar .46 to get it running well on 5% other than installing a hot glow plug and fueling it up.
Old 08-17-2009 | 10:07 AM
  #61
faulknej's Avatar
My Feedback: (9)
I hope it goes that well. It shakes a lot, things keep vibrating out of it...i.e idle stop screw, mount bolts, etc. I hope it settles down soon.
Old 08-24-2009 | 06:53 AM
  #62
faulknej's Avatar
My Feedback: (9)
I'm having the same idle problems now too. Runs sweet on the top end, 13200 with an APC 11X6. No transition though. LSN seems to have no effect on the transition, It stutters, coughs, takes about7 seconds to get to full throttle. Best idle I can get is 3000. Could I have one of the wrong carbs?
Old 08-24-2009 | 08:31 AM
  #63
jeffie8696's Avatar
Those are the classic symptoms.
Old 08-24-2009 | 11:54 PM
  #64
faulknej's Avatar
My Feedback: (9)
Ireally wanted to maiden the Tiger this weekend. Looks like that will have to wait . You'd think they would have fixed all the engines by now. I've only had this one a few weeks. How long has this been going on?
Did the .53 have similar problems?
Old 08-25-2009 | 12:56 AM
  #65
faulknej's Avatar
My Feedback: (9)
Which number on the SIG page do I call? Anyone in partcular to ask for? Thanks
Old 08-25-2009 | 07:55 AM
  #66
jeffie8696's Avatar
800-247-5008 Bob
Old 08-25-2009 | 07:58 AM
  #67
faulknej's Avatar
My Feedback: (9)
Thanks Jeff.
Old 08-25-2009 | 08:14 AM
  #68
faulknej's Avatar
My Feedback: (9)
Bob told me to send it in. Can't wait to get the new one back. woohoo!
Old 12-03-2009 | 09:23 PM
  #69
ORIGINAL: faulknej
How did it go?
Frank
Old 12-14-2009 | 12:42 AM
  #70
faulknej's Avatar
My Feedback: (9)
Wow. it's been a while since I posted that. Igot it back and put it in a Tiger 2. The plane never landed with the engine running. 12 flights, all deadsticks. The last one planted the engine about six inches down in the dirt. Broke the carb off. Good riddance. My experience with the Aviastar brand was not good. The .53 I bought broke the conrod on the second breakin tank. I just threw it in the trash with the .46. I'll stick with Magnum and YS.
Old 04-10-2011 | 06:26 AM
  #71
Bonified Wingnut's Avatar
I hope not too many new flyers buy this for their first glow engine. If they do I doubt they will stay in the hobby long.
Old 05-02-2014 | 05:01 AM
  #72
Can't I just buy one of these .46 engines and break it in without all this changing of fuels and head shimming? I run Omega 15% with caster for the .46 OS AXII engine I have now.
Thank you very much.
Dan
Old 05-13-2014 | 08:48 AM
  #73
Dan
Your Aviastar .46 should run fine on Omega 15% nitro fuel. I'd recommend trying a Fox RC Long glow plug w/ idle bar or an O.S. No. 8 plug. The 15% nitro content is a little high, so a medium/hot plug will likely run more reliably. A hot plug like an O.S. No. 6 (A3) may cause pre-ignition issues with higher nitro fuel.
Good luck!
Old 05-13-2014 | 04:27 PM
  #74
1QwkSport2.5r's Avatar
Good luck!
I run McCoy MC59 or Enya #3 plugs in most of my engines which are both hotter than the plugs you listed with fuels ranging from 5% nitro up to 30% nitro and dont have issues with preignition or detonation. Car engines running at 35,000rpm or 4-strokes running at 12,500rpm don't matter. Just need to remember "Lean is Mean". If the engine is over compressed with higher nitro, you will need cooler plugs and/or less nitro. The cheapie engines tend to be under compressed so more nitro is tolerated. Truly though, the only way to determine what plug the engine needs is to try several plugs and using a tach take note of the results. The tach will tell you which plug works best.
And for the record, idle bar plugs aren't intended for Schnuerle ported engines. They are designed for use in cross flow ported engines.
Old 05-13-2014 | 06:46 PM
  #75
Good luck getting one that runs. I gave up trying to get mine to work and gave it a friend. He put a different carb on it and it still would not keep running. The engine never completed a flight running. Try doing a search on You Tube and see if you can find many videos of the thing airborne. Then do a search on any other engine. All I can say is good luck.
