Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
WEBRA SILVERLINE
Old 06-23-2009, 06:23 PM
tony0707
Default WEBRA SILVERLINE
HI i have an older webra silverline 61 can you tell me the best size apc prop to run on this engine- and the RPMS i might expectusing an 11/6 apc running a little rich at 12,30012,4000 would like to run an 11/5 apc or should i be thinking -11/7 thanks
Old 06-24-2009, 10:52 PM
rainedave
rainedave's Avatar
Default RE: WEBRA SILVERLINE
I think 11x6 is as small as I'd go. 11x7 or 11x8 are probably best for that engine. Those are the props the engine was designed to turn.
David
Old 06-25-2009, 12:32 PM
tony0707
HEY DAVID thank you for your inputTONY
Old 09-02-2009, 05:41 AM
Johnkpap
Johnkpap's Avatar
My 1960's webra 61 (10cc) runs best with a Master Airscrew 12 x 8 Prop, it likes heavy props:- I found wood ones
to have Idle issue and problems with midrange.
Johnkpap
Old 09-02-2009, 11:50 AM
anuthabubba
My Feedback: (102)
I was gona suggest a 12~6 as most of these older .60s were designed to use. The rpm may be down a bit but depending on the plane this could make a good combo. Mainly, you have to do a bit of experimenting.
Terry in LP
Old 09-03-2009, 01:33 PM
Sport_Pilot
Sport_Pilot's Avatar
If this is a 70's or 80's Silverline, i expect the 11-7 prop would be best. Especially on a pattern or pattern like aircraft.
