Mvvs .77 Idling
Mvvs .77 Idling
Very good performance but it is very hard to tune low end.
While idling, when I close the carb hole with my finger, engine continues to run, carb has an air leak.
Is anyone experienced this problem ?
Thanks.
Thanks.
Mvvs .77 Idling
there is a O ring at the (bottom) neck of the carb
check if it seals properly - loosen the retaining screw nut (carb), PUSH DOWN while tightening again
this could solve your problem
worn carb
obolel,
Yes I have had this problem - also on a 77. The carb had a leak between the body and barrel. Had to replace carb with a new one from Morris Hobbies.
Tom...
Tom...
