RCU Forums
-   Tachometer Readings (https://www.rcuniverse.com/forum/tachometer-readings-173/)
-   -   Webra 91 P5 (https://www.rcuniverse.com/forum/tachometer-readings-173/3048787-webra-91-p5.html)
PlaneKrazee 06-06-2005 07:32 PM
Webra 91 P5
Apc 16X6, Byron 5% nitro 18% oil, home brewed quite muffler, about 75 degrees with moderate humidity. 8850 rpm a little rich.
At peak rpm the setup on a Funtana 90 gives 89 db @ 9 ft.
Hobbsy 06-29-2005 05:51 PM
RE: Webra 91 P5
Brian, is yours smooth when doing this, mine is very smooth turning the APC 14x12 at about 8,200.
PlaneKrazee 06-29-2005 09:51 PM
RE: Webra 91 P5
The engine is smooth and the throttle is very linear. I tried to get the db lower by using a Dubro mount but that was a waste of time. The airframe is like a huge drum. If you talk loud next to the wing it amplifies your voice.
