RCU Forums
-   Tachometer Readings (https://www.rcuniverse.com/forum/tachometer-readings-173/)
-   -   61FX / Davis Pipe (https://www.rcuniverse.com/forum/tachometer-readings-173/326519-61fx-davis-pipe.html)
rctimm99 10-22-2002 05:45 PM
61FX / Davis Pipe
61 FX / Power masters 15% nitro with a Davis Quite Pipe...
11,100 Running an 12X10 pattern prop. This puts my OS 91 FX to shame ;-)
Tim
sparky925 10-27-2002 02:49 AM
Davis quiet pipe?
Just got OS.61..
Where to get pipe and info about it??
:confused: :confused: :stupid: :devious:
rctimm99 10-28-2002 06:01 AM
61FX / Davis Pipe
The Davis pipe is about 130 bucks, and not as good as the MAC. I would simply order a MAC pipe and header. 60 bucks, and you are screaming. If you are are trying to quite it down, go with the Macs quite pipe... both are good choices. Tower has them.
Tim
Phil Heller 11-04-2002 03:01 AM
61FX
-----Or get a Performance Plus tuned muffler! You will pick up 500 -
1500 RPM, depending on the prop you are turning, I can guarantee it! Mine will turn a Scimitar 12-6 at 14k and an APC 11-7 at 15500! This on Wildcat Plus 15%. In the air it sounds like it picks up quite a few more revs.
rctimm99 08-19-2003 03:55 AM
ok... that lasted one day
28 bucks... bocca bearings... blew the front bearing ;-)
bob_nj 08-22-2003 11:15 AM
61FX / Davis Pipe
Is there an address for Performance Plus_bob
RossiRay 08-22-2003 04:58 PM
61FX / Davis Pipe
Performance Specialties
Home of the Nelson tuned muffler.
www.pspec.com
bob_nj 08-22-2003 05:28 PM
Nuts
There isn't a performance pipe available for my Rossi .60. Actually I got this engine from Morris years ago and used it for about a dozen flights. I have the Rossi pipe, but was hoping for something a bit lighter. Any ideas Ray? Thanks_bob
RossiRay 08-23-2003 02:49 AM
R.60 exhaust
Did you talk to Dave? I thought he made an adapter to mount the UT onto Rossi's.
Check with Jett also.
bob_nj 08-23-2003 06:46 AM
61FX / Davis Pipe
I sent him an email. Thanks_bob
