How do I reverse rudder direction?
My Feedback: (24)
Howdy,
I have a new Albatros with the Tactic Anylink connected to a Spektrum DX6 transmitter. Following the instruction sheet, I programmed the Anylink for the Spektrum radio. I use Mode 2 and have throttle on left stick, elevator on right stick, and rudder on left stick also.
But my rudder turns opposite of my control movement. Since the radio is technically turned off, I cannot access programming. Or, can I? I am quite confused by all this as I never normally use a DSC function for any purposes.
Should I find an empty model channel on my Tx and only connect the Anylink on that? If I do this and the rudder moves opposite, can I disconnect the Anylink, power up the DX6, enter the menu and reverse rudder, power off, re-connect the Anylink and have rudder moving according to stick input?
Thanks for any advice.
