SOLUTION - ? How To Mix Elevator > Flap TTX650 ?
TX
Wing setup is 2Al 1FL, servos in ch.1 and ch.6. I can get flaperons and differential ailerons but I can't seem to figure out how to mix elevator to flap so as to get flap opposite to elevator to assist in square corner maneuvers. Haven't been able to program a mix to accomplish this. Can you help?
Thank you.
Tepid Pilot
ps - TTX650 is a pretty cool product. I like mine real well.
GOT IT!! Thank you Bax, er... Bill. You got me pointed in the right direction. See third post for what I did.
Thank you.
Tepid Pilot
TX
ORIGINAL: Bax
You'll need to use two of the mixes. One will be elevator->aileron (channel 1), and the other will be elevator->channel 6 (2nd aileron channel).
Short version is only one program mix is needed: Elevator (Ch2)-> Ch6, with both the L&R rates set to +XX%, no offset. I use 100% for now, pending flight tests. This applies when the flap setting is 2AI 1FL, right aileron is Rx Ch1, left is in Rx Ch6. I have no personal knowledge of what happens when using the other flap settings.
Longer version is, after trying what seemed like an infinite number of permutations and combinations of L & R and +XX% & -XX% using the mixes you suggested, and only ever getting the aileron channel to cooperate but only in one direction, e.g. up elevator/down flap but down elevator down flap, and the Ch6 flaperon feebly waving in one direction or the other, all the while with the ailerons and flaperons continuing to function normally, I got crazy and went way out. Eventually, I wound up with two mixes, both Ch2 -> Ch6, one set to L +100%, the other to R +100%, and BINGO! From there it was a short, sane leap to combining the L&R settings to just one mix, and deleting the superfluous one.
Now I have what I originally sought, flaperons with settings for off, reflex (just a pinch), and flaps, along with the elevator -> flap mix for really, really square corners.
It is my fervent hope that this experience can help other folks.
TP
NC
thanks tepid for the information. For the above setup does your plane actually have 2 seperate aileron connections or are they on a y harness?
I ask since I have a flyzone acrowot that uses a y harness for ailerons, and I wanted to see about having flaperons for landings. Keep it up and you will become the go to guy for ttx650 setups
<br type="_moz" />
<br type="_moz" />
TX
ORIGINAL: ncsky
Post #90 in this thread [link]http://www.rcgroups.com/forums/showthread.php?t=1830737[/link] has a more complete description.
Also, it pays to keep notes when you are assigning features to switches. Don't ask me how I know.
TP
