Tactic Questions
I am going to pick up a new Tactic TTX650 transmitter or two. I have had lots of good luck with 2 or 3 different Tactic receivers. I came across an orange Micro 4 channel receiver that is super light. Is it compatible with the TTX650 tx? If you are unaware of that tiny rx I will try to find it. Thanks.
Steve........................That is perfect, size and weight. It has only been a short time since we graduated to the tiny stuff. Do you recommend a quality, light weight, servo for this application? I would like to use servos in the 2 to 2.5 gram arena. Thanks for all the help.
My Feedback: (14)
IN
http://www3.towerhobbies.com/cgi-bin...?&I=LXBPYD&P=7
then you might want to try this unit. It is what is installed in the flyzone micro planes and i am getting ready to install a couple in some Stevensaero planes that i built.
