Tactic & AnyLink Support Forum Ask any questions you may have about AnyLink and Tactic systems here and get answers direct from their team.
Reduce stick sensitivity???
Old 11-14-2015 | 11:28 AM
My Feedback: (178)
Default Reduce stick sensitivity???
The aileron stick on my Tactic 850 is so sensitive that when I move the elevator the ailerons move....can I adjust expo to solve this? Thanks
Old 11-16-2015 | 07:39 AM
Bax
Yes, you can use exponential to soften the movement of the channel around the center of the stick movement. Set the exponential number to a negative value to desensitize it around center.
