Tactic & AnyLink Support Forum Ask any questions you may have about AnyLink and Tactic systems here and get answers direct from their team.
650 and 660 timer
Old 02-02-2018 | 11:54 PM
Default 650 and 660 timer
A timer question please: I assigned the timer to switch D on both of the above. Got the 660 recently for the slide levers etc. The 650 needs the two left rear switches repaired, levers snapped off. I discovered that I have to throw switch D twice: on off then again on to activate it. Same for both radios. Is this normal? I haven't flown the 660 yet and the 650 is 3 years old and works perfectly except for the two switches mentioned. I don't have them assigned to anything anyway.
Thanks for any advice.
Bill
Old 02-14-2018 | 12:10 PM
You can set the switch to activate on "1" or "0"
Try changing it to see if it starts the timer the way you want.
Jenny
