Starting Over.
Starting Over.
Okay so I recked my MMGT 3.0 pretty bad. Lost controll and the truck went full speed into a wall and busted the frame to the point that I cant put the stock body back on. So I decided to rebuild from the Frame up. I am going to be changing alot of the parts including servo's and possibly the controller all together with a 2.4ghz system. I have seen a big block upgrade which will be nice since I am looking to put some huge tires on (jumbo Kongs ithink). So This will be my first post and I will try to Update as I go... I dont have any money yet so i just took the thing apart today and here is what I am left with.
Aight if you guys and gals have any suggestions on what Motor will be the best That would be great I have found everything that I can put in except the motor.
Thanks in advance.
~Joe
Thanks in advance.
~Joe
RE: Starting Over.
Just curious I thought the big block kit was able to fit the .21 and .28 in it from AE. The pics I have seen for the .28 doesnt appear compatible with the truck what so ever.. Are there any other motors that would work easily i dont really feel like doing a hole major job just to put the motor in.
~Joe
Just noticed that there is a good range of engines that coule fit the conversion... what is the best one...???
Includes engine mount, hardware and special bellcrank. ) From New Era Website...
~Joe
(MMT110 details:
Mini MGT Big Block Conversion. Install a .21 to .32 engine in your Mini MGT.Includes engine mount, hardware and special bellcrank. ) From New Era Website...
NY
RE: Starting Over.
The New Era Big Block kit make ANY .21 to .32 engine a direct drop in. Any quality .21 to .32 engine will be more then enough for the Mini.
AL
RE: Starting Over.
i got a ae .21 in my mgt 3.0 thing does wheel when u only put a lil pull on tiger if i pull it all the way truck goes cravy with frontwheel off the ground flips and land on itback
i post pics later today
