Team Associated - Monster GT Discuss all things AE MGT right here!
Need a quick pic please!
Old 05-06-2009 | 10:27 PM
Default Need a quick pic please!
I am looking for a picture of the throttle arm that is on the carb for the MMGT 3.0 stock Team associated pro 18 motor. I cant find a part number for this part and wanted to match it from looking at it. Thanks!
Old 05-06-2009 | 11:27 PM
Default RE: Need a quick pic please!
http://67.199.85.166/main/productdet...ory=3015.mmgt3
This one?
Old 05-07-2009 | 12:17 AM
I dont think so.
I belive it should look something like this
Its on the carb itself.
Old 05-07-2009 | 03:04 AM
My Feedback: (12)
I took a picture of my mini, and I circled what i believe your looking for, or at least the part you are looking for is in the pic......... If the part your looking for is in that circled area then the link dabull posted is correct, and you have to buy the whole linkage setup because its going to be hard to find a place that sells those pieces separately, which I'm not even sure if those pieces are sold separately:
Old 05-07-2009 | 10:54 AM
Hey man thanks!
It is actually the part that the metal post is hooked too. Not the ball link side but on the motor. I think its called the throttle arm. There is a nut that holds it on to the carb. I would need both those parts but it doesnt seem to be available anywhere. Any thoughts?
Old 05-07-2009 | 12:19 PM
My Feedback: (12)
Are you talking about the nut that is screwed onto the ball link shown with the green arrow is pointed to? The blue arrow is pointed to the pivot ball as well............I'm confused to which part your actually looking for.......
Old 05-07-2009 | 05:43 PM
Hey, what is that blue thing on your fuel line?
Old 05-07-2009 | 05:57 PM
My Feedback: (12)
It's a fuel filter, it prevents any debri that may go into your engine, just incase your fuel tank becomes contaminated etc.......
Old 05-07-2009 | 06:31 PM
Dammit, I guess that's something else I'll have to buy. Thanks a lot. JK
Old 05-07-2009 | 10:05 PM
ORIGINAL: ilanstylz
The pat Im talking about is between the two arrows. Its the throttle arm on the carb. The nut and peg hook to it...Ill find a sorta same looking pic.
http://www3.towerhobbies.com/cgi-bin...?&I=LXMML5&P=7
Old 05-08-2009 | 12:47 AM
He's talking about the arm this is physically bolted to the carb. The throttle arm, not the linkage. The black piece that the low speed needle screw is surrounded by
Old 05-08-2009 | 12:55 AM
My Feedback: (12)
Ok I was thinking that was the part he needed but wasn't sure.......However this is the part number you were looking for, it says its for the ae .15 but it'll work on the .12 and the .18 as well:
http://www3.towerhobbies.com/cgi-bin...9044&search=Go
Old 05-08-2009 | 10:41 AM
Thank you VERY much guys! I put it on my order.
Happy R/c ing
