Team Associated - Monster GT Discuss all things AE MGT right here!
MMGT idle problems
Old 03-25-2010 | 08:25 AM
Default MMGT idle problems
Hey all my MMGT's carb is staying open to far . I have tried to ajust carb with no luck. It looks like the servo isn't reurning all the way back. How can I fix it? Thanks
Old 03-27-2010 | 06:53 AM
scott36's Avatar
My Feedback: (54)
Default RE: MMGT idle problems
it could be a end point adjustment needed if your radio has that. or you may need to pull the servo horn off turn it on the servo splin so you get a good idle gap and put the horn back on the servo.
Old 03-28-2010 | 10:04 AM
I am havingt the same issue. When it starts, it runs wide open and I have tried everything I know...................[&o]
Old 03-28-2010 | 02:19 PM
Unscrew the servo horn on top and reposition. It worked for me, thanks scott for the help.
Old 03-28-2010 | 04:58 PM
scott36's Avatar
My Feedback: (54)
Crash
glad it worked out for you....
now for MAXXPAYN if the throttle is going wide open on start up is the radio working properly? do this with out the engine running, get the idle gap set in the carb so it is at the manuals settings also make sure that when applying the brake that the idle gap dose not close so that the engine would stall.
Old 03-29-2010 | 08:20 PM
Thanks Scott. I will try that. The radio seems to have some glitching issues .....
Old 03-30-2010 | 03:47 AM
scott36's Avatar
My Feedback: (54)
forgot to say to make sure the batteries are charged
