Mike, Will Your New SU-26MM run ok with a DA 100?
Mike,
Awesome job you did on the new Suckoi! What a great looking and well designed plane. Just wondering if I can fit a DA 100 in that bird. I know it will fly better with a 85 but I have the Da 100 ready on the bench.
Have you test flown it with the 100? If so how it flies with it?
Thanks Mike and keep your good work!
Serge
Serge
RE: Mike, Will Your New SU-26MM run ok with a DA 100?
Have not flown with the DA-100. The power here (at 500 feet) with the DA-85 is insane. A 100 would be too much. It would fit in the cowl except for the spark plug caps.
21.75 lbs with DA-85, MTW 110 canister, single 8611A on ailerons, 2 x 4500 mah Lipos for rx ans 1 x 4500mah lipo on ignition and pilot figure installed.
