Showtime 90 4d CG help
FL
Hey Mike,
Although they have been out for a little while, I just recently got the showtime 4d 90 size. I understand this plane can do pattern type flying as well as hovering and such. I am mainly into the hovering and other 3d stuff and was hoping you or someone could tell me what might be the optimum cg for this kind of flying or whether shifting the cg from what it says in manual makes much difference in the 2 flying styles?
Mike
Mike
FL
RE: Showtime 90 4d CG help
Thanks Mike,
Main reason I asked is I have it set at stated cg but was getting some wing rocking in pure vertical hover. Would you know if a more forward or aft cg might help this?
Thanks again
Mike
Thanks again
Mike
FL
By forward, you are referring to making it more tail heavy, correct? Yes, I tried the SFG's and it was still there a bit plus I still havent quite got used to them so they have been off and on a couple times..
