Flybar
1 Post
Flybar
I haven't been paying much attention to my raptor lately but when i fly it the flybar twists round and the paddles end up vertical does anyone know what could be wrong. I'm goin to strip it down now but just thought i'd asked to save some time.
NY
RE: Flybar
HI THERE!
IT SOUNDS LIKE YOUR NOT SETTING UP THE FLYBAR RIGHT ON THE MACHINE. THERE ARE TWO FLAT SPOTS ON THE FLY BAR WHERE THE SET SCREWS LOCK IT IN PLACE MAKE SURE THAT THEIR FACING UP, YOU SHOULD BE ABLE TO SEE THE FLAT SPOT BEFORE YOU INSTALL THE SET SCREW (REFER TO MANUAL!) AND ADD A DROP OF BLUE LOCK TIGHT ON THE SCREW.
1 Post
RE: Flybar
By the way its not just the flybar that moves the oval linkages along the side of the swashplate and main shaft move as well. I can wobble the paddles about and the linkages move with it without any servo movement
TN
RE: Flybar
maybe you washout asmbly is warn out. also check the set screws in the leading edge of the flybar paddles, perhaps the paddles are rotating on the flybar
NY
RE: Flybar
I SUGGEST THAT YOU INSPECT THE WHOLE CYCLIC SYSTEM, YOU SHOULD START WITH THE SERVO'S YOU SHOULDN'T HAVE THAT MUCH PLAY ON A STOCK RAPTOR YOU COULD BE MISSING A FEW TEETH ON THE SERVO GEARS AND MAKE SURE ALL YOUR BALL LINKS ARE TIGHT.
GOOD LUCK!
SAUL.
GOOD LUCK!
SAUL.
